N2 AE86 Levin
06-10-2007, 11:54 PM
N2 AE86 Levin
Hi everyone, this is my new N2 kitted AE86 Levin, some pictures of the car as i collected it.
Thumbs up!
[Image: AEU86 AE86 - N2 AE86 Levin]
As i am going to use the car in some drift events later in the year i decided to strip out the rear of the interior, the sound deadening is a nightmare to remove! Also had to remove around 2kg of speaker wiring from previous install!
Arches will be re-plated for extra strength and the interior sprayed Satin Black.
Job after that will be a compression check on engine and fix leaking brake caliper along with project mu rear pads! Thumbs up!
06-11-2007, 12:15 AM
N2 AE86 Levin
It looks very nice, with the arches and NO rear wing. Keep her that way!
[Image: AEU86 AE86 - N2 AE86 Levin] http://www.jdmbits.com
06-11-2007, 01:04 AM
N2 AE86 Levin
looks very clean. altough you will always find some rust! Thumbs up! do some work on the rust or it will ruin your paint.
n1 car mate!
06-11-2007, 10:32 AM
N2 AE86 Levin
The bodywork and kit will be staying the same for sure, just some mechanical and interior work being done Thumbs up!
06-11-2007, 11:29 AM
N2 AE86 Levin
Hot DAMN!
It is a beauty!
Maybe consider a change of rims? I mean let the rotors breath a bit... =)
Nice car, looking forward to seeing it in action!
06-11-2007, 05:24 PM
N2 AE86 Levin
Nice! Thumbs up!
Did you install the flares yourself? Dumb question
06-11-2007, 05:52 PM
N2 AE86 Levin
Looks nice! how much horespower do the hachi have?
06-11-2007, 06:31 PM
N2 AE86 Levin
banpei Wrote:Nice! Thumbs up!
If I am not wrong, he just bought the car and the kit is already there when he bought it
06-11-2007, 08:08 PM
N2 AE86 Levin
Yes the kit was already fitted when i bought the car, not sure what power it is kicking out is virtually standard apart from exhaust, trust 4-1 manifold, HKS mushroom filter and HKS cams
06-11-2007, 08:15 PM
N2 AE86 Levin
Spec list of the car is;
Body and wheels;
Full N2 bodykit apart from rear wing
Recently resprayed black
14" ssr MK1 wheels
10J 195/60 rears
9J 185/60 front
Tinted rear window
Engine;
New radiator
recon stater motor
New clutch slave cylinder
New gear box oil
New diff oil sleal
New diff oil
Trust exhaust manifold
full under axle exhaust (very loud )
HKS cams
HKS air filter
TRD plug leads
Suspension;
T3 camber plates
white line panhad rod
T3 Rca
Tein coilovers
4 months old Tokiko shocks adjustable dampers
Interior;
Recaro bucket drivers seat
recaro recliner (from evo3)
Metal flake steering wheel
DW gearknob
