LEEN Gearbox Conversion: LexusIS200 AZ6 to Toyota "A&qu
09-28-2011, 01:04 AM
Many of you know about my trials and tribulations over getting the AZ6 adapter finished. Where I failed - Joe, from LEEN Gearbox Conversions, has spent the time, and money to bring this to the community. The first run of 5 units is now finished there is 4 units presold, that leaves one unit available for sale!!!! Once these 5 units are sold, Joe's intentions are to make a 2nd run, adding a few more units in each successive production runs.
LEEN Gearbox Conversions Wrote:And now, watch and enjoy :thumbsup: Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-28-2011, 06:51 AM
Looking good, a bit more expensive than I've hoped for... The whole kit adds up to shy over 2k€ plus the gearbox itself... oh well eventually I'll find the $$$$ for it
AE86 ex-daily |
09-28-2011, 12:53 PM
You get what you pay for in this world.
09-28-2011, 01:03 PM
Well the difference to quaife box is not that big anymore. TRD gear set is about the same price but I have to admit I like the AZ6 gearnox idea very much.
AE86 ex-daily |
09-29-2011, 02:31 AM
I still don't see why you prefer this above a W58 or something, only because of the 6th gear?
09-29-2011, 02:43 AM
bozu Wrote:I still don't see why you prefer this above a W58 or something, only because of the 6th gear? It all has to do with gear spacing..... For those that like to see charts :wink: Using a 3.9 final drive Using a 4.30 final drive Bean Bandit Wrote:TRD gear set is about the same price but I have to admit I like the AZ6 gearnox idea very much. but you are still left with a weaker gearbox... the TRD gears are a bit stronger, but the box is still the weak link. So for the same price, you get better gear spacing, a stronger gearbox, and better fuel economy Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-29-2011, 02:59 PM
Will be driving this setup hopefully next year.
Superb work there guys! And Joe from Gearboxconversion.com thanks for the updates everytime! 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
09-29-2011, 08:25 PM
This might be the most important chart.... for it shows a LOT of interesting info... 1) note that the gap in the T50 box between 2nd and 3rd... is now shortened... This alone will improve acceleration times. 1a) Another note they are all shortened a bit... actually the shift doesn't extend to the 4th/5th split, and so the gap in the 6 speed is actually a bit wider... since 4th to 5th in the T50 is not a huge gap 2) note 1st gear is nearly a perfect overlay of 1st in the T50. That means starts will be nearly identical if you run a 3.9 final instead of the 4.3 3) Why run a 3.9... note how much taller 6th gear is now... the rpm will drop significantly now... and if you do 70+ on the highway you will now be able to avoid being "in the TVIS" while on the highway... ++++ for MPG 4) Additionally, if you have the hp, and you want to go FAST... you know have the capability (gear to engine speed) of hitting 150mph Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-30-2011, 09:58 AM
Would be cool to see this graph too with a 4.1:1 ratio.
09-30-2011, 02:51 PM
oldeskewltoy Wrote:bozu Wrote:I still don't see why you prefer this above a W58 or something, only because of the 6th gear? Then I would like to see one of those graphs with a W58 in their as well cause I'm still not convinced. Don't get me wrong by the way I'm not trying to talk your product down cause I respect the research and the end product looks really good. Just trying to get a clear picture of why this would be a better choice over a W58 gearbox which is close ratio and capable of handling more then 300hp |
Speed Industries: F20c conversion parts (mounts..) | speed-inc | 4 | 6,999 |
02-09-2012 11:11 PM Last Post: roiz86 |
Speed Industries: f20c conversion parts | speed-inc | 2 | 4,117 |
06-22-2009 02:35 PM Last Post: benjy_b |
AZ6 Swap Available! | oldeskewltoy | 8 | 15,217 |
10-23-2007 06:57 AM Last Post: oldeskewltoy |
"old school > everything else" sticker | OSI | 1 | 4,453 |
01-11-2006 08:31 AM Last Post: OSI |
"I Love My POS" Stickers | OSI | 9 | 9,655 |
11-30-2005 08:27 PM Last Post: OSI |
