Ivan's coupe: roof stuccowork
02-20-2022, 02:01 PM
Post: #601
It is starting to look like a genuine car again!
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
03-02-2022, 12:51 PM
Post: #602
Does anyone here have experience with replacing the U-joints in the driveshaft?
2 out of the 3 u-joints in my driveshaft feel notchy, a clear indication that they are past it. They are of a non-servicable type officially, so I cant easily find any replacement joints that should fit, although I suspect they do exist. I read on Billzilla's old site that some common size may be fitted after some machining but I would prefer to avoid that. A local driveshaft shop thinks they can get it done for me, but at €400 the cost is staggering. FABRICA MI DIEM, PVNC! |
03-02-2022, 07:29 PM
Post: #603
I had my driveshaft serviced last year.
Replaced all 3 U-joints with: GMB 016-GUT24 Parts cost was 79€ and the replacement work and balancing of driveshaft was 330€. |
03-02-2022, 11:05 PM
Post: #604
Thanks.
I may just have to swallow the cost on this one. Proper u-joint installation would already be difficult enough, but getting these staked ones mounted correctly looks a bit too difficult. Havent seen that part nr before, but the size looks familiar to others I've found (GMB 200-0024 / Febest ASM-CW5). Need to remeasure (cant find my calipers) since I could swear the hole diameter was 24mm when I checked last time. From what I've seen these solid ones are a better choice than those with grease fittings. In these small sizes those tend to snap when confronted with a bit of abuse. The tricky bit with mounting new ones is getting them centered properly and making sure the axial endplay is within specification (<0.05mm). That last one is hard to do in a shed. Rebalancing should not be necessary but it is probably not the biggest part of the cost. FABRICA MI DIEM, PVNC! |
03-05-2022, 12:46 PM
Post: #605
Progress report:
-Bent up new cunifer brake lines for the rear axle. Not an easy task, but the result looks like it will work: Next to crusty old suspension for contrast: What's this? No more rotisserie, thats what. The eagle has landed: Todo items on my mind these days: -Refurb driveshaft. I ordered 3 new u-joints for about €30. I'm going to attempt it myself. As long as I dont screw up the yokes I can still dump it at a specialist store if DIY doesnt go well. -Prepare reconditioned rear brake anchor plates and hardware for mounting to axle. (zinc-plate the bolts/nuts, clean up my 'new' calipers. -Buy some stuff for finishing off the rear axle (solid spacer kit, gasket kit, axle end plates). When I have a working parking brake again the next priority is getting the shell reunited with the doors and trunk/bonnet so we can start 'mudding' the heck out of it. FABRICA MI DIEM, PVNC! |
03-06-2022, 09:55 PM
Post: #606
That's some great progress! Finally she's on her own feet again!
So which car is next in line for the rotisserie? 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
03-07-2022, 04:03 PM
Post: #607
Nice! Keep up te good work and the momentum. She’s almost ready for MOT!
AE86 Levin |
03-08-2022, 09:44 AM
Post: #608
Nice work!
03-21-2022, 10:09 AM
Post: #609
good work!
Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
05-04-2022, 12:58 PM
Post: #610
I'm following this with much interest.... great work Ivan
Front end roof compatibility between 2dr and 3dr | Dochka | 11 | 12,049 |
01-12-2014 05:50 PM Last Post: fax0815 |
