Is my 86 special?!?
03-25-2007, 09:59 PM
Is my 86 special?!?
Depending on what 'new front end' defines - maybe he got the front portion from an SR-5, which would explain everything...
03-27-2007, 12:49 AM
Is my 86 special?!?
parrot Wrote:Well in that case, only thing I can think of is that it was fitted with an airflow meter intake at some stage as with the USDM versions? They have a different airbox and intake tube across the radiator than the JDM UKDM versions. Perhaps that airbox will fit onto that bracket. It is definitely the bottle mount as found in AC versions however. No, USDM intake air boxes won't fit with that bracket there. Andrew |
03-28-2007, 01:55 AM
Is my 86 special?!?
Sounds likely. If you grind off the bracket, all the bolt holes for the standard airbox are in place to bolt it up.
03-29-2007, 09:29 PM
Is my 86 special?!?
I won't grind of the bracket since my car has a fresh paint job
Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
03-30-2007, 01:48 AM
Is my 86 special?!?
Bummer, it is only a couple of spot welds on each side though. I just went carefully and and it only needed a small touch up, with primer and top coat. It is well hidden by the airbox when in place.
Need special parts | gh0st | 4 | 2,430 |
09-11-2021 02:23 PM Last Post: gh0st |
SPECIAL AE86 WHEELS GUIDE !!! | eg6maxx | 51 | 310,685 |
09-02-2012 12:31 PM Last Post: Skyracer |
SST (Special service tools) questions. | Ryo | 4 | 7,262 |
04-06-2011 07:51 PM Last Post: Ryo |
Toyota Special Service Tools (SST) | S.K. | 2 | 9,437 |
10-25-2009 05:13 AM Last Post: yoda8 |
