Factory Electrical wiring diagrams & engine diagnosis ma
01-12-2007, 02:12 AM
I have scanned up the AE86 factory detailed Electrical Wiring Diagrams Book (1983) as well as the factory 4AGE TCCS Diagnosis Manual. Both have been my bibles for the last few years. Very useful.
Both are on this site in PDF see below, now on aeu86.org server The EWD is very detailed and contains each seperate circuit and illustrates each plug and where each wire goes within it. Not just the basic schematic diagrams, though they are there too. Engine diagnosis manual takes you through step by step for ECU and wiring related faults. Includes pinouts. This applies to AA and AE body series with 4AGE Edit: AE86 Wiring Diagrams EU/AU (1983) by Parrot (5Mb): AE86 Wiring Diagrams (EU/AU) AE86 Wiring Diagrams USDM (1986) by Parrot (5Mb): AE86 Wiring Diagrams (USDM) 4A-GE Diagnostics Manual by Parrot (8Mb): 4A-GE Diagnostics Manual |
01-12-2007, 02:39 AM
it has tons of info. too bad it doesn't have the electric window diagrams because is for 1983...
those i needed Pedro Velado GT-S Owner |
01-12-2007, 02:47 AM
No problem, I have those too, BUT for the USDM model. The US looms are very different from the Euro looms however I expect the power window section would not vary much until it gets to the junction box. Though actually I note you are in Central America which I presume have LHD US spec GTS's.
I do not have this electronically and it was difficult enough getting access to a scanner to do these two files. If you PM me either a fax number or an address I can send them to you on Sunday morning Australian time |
01-12-2007, 06:22 PM
Parrot: Is it okay if we mirror the diagrams?
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
01-12-2007, 07:15 PM
Yes parrot, i drive a USDM LHD corolla.
Please mail the diagrams to [email protected] . Thank you so much, I really appreciate it since I'm having problems with my passenger side window, I cannot open it, unless i take off the door panel and do it manually Pedro Velado GT-S Owner |
01-13-2007, 08:35 AM
Banpei - absolutely. I shall try and put up the USDM EWD and other assorted useful things at some stage. Scanning is not so easy unfortunately but I am working on a way around that.
Pedro - if you want it emailed you may have to wait a while as it isn't scanned. I shall see how I go. I can post or fax though. |
01-13-2007, 01:18 PM
I know the problem. I promised I would scan my EWD as well some time ago, but I never found the time to do it.
But I've put them up here: http://files.aeu86.org/manuals/ewd-ae86-...parrot.pdf http://files.aeu86.org/manuals/4age-diag...parrot.pdf As you can see I've put your name in it. Thanks again! Edit: I've also added them to our Technical FAQ section. http://www.aeu86.org/viewtopic.php?p=35506#35506 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
01-14-2007, 01:10 AM
I'm famous!! Thanks Banpei.
Have just finished copying the USDM EWD too. It has all sorts of odd things such as the trueno pop up light circuit, cruise control, power mirrors, power windows etc. I shall try and get this scanned on Tuesday and advise when it is up. |
01-14-2007, 02:14 AM
Hopefully it contains the power sunroof circuit as well. It's not that difficult but I want to check myself if I discovered the wires correctly...
1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
01-14-2007, 12:05 PM
The sunroof circuit is in the Euro version already listed above. Not hard, it goes from the junction box in the drivers footwell.
Tail light wiring... | Mylesmck | 4 | 330 |
02-02-2024 12:36 PM Last Post: Mylesmck |
Lambda sensor wiring | sam3007 | 10 | 3,256 |
Where to run the factory antenna cable | andyling | 2 | 3,171 |
09-30-2020 12:31 PM Last Post: andyling |
4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 6,300 |
06-20-2019 11:38 AM Last Post: Lykowsky |
Some wiring help needed | DJexor | 5 | 4,792 |
