Engine cranks slowly when hot... but starts
01-30-2014, 06:02 PM
I have an issue with my AE86.
Car starts when Engine is cold. When Engine is hot, the starter motor cranks very slowly (Engine revolution is maybe 1 per 2 sec or so... really slooooow)... but it always fires up. It feels like after one rev, out of nothing it starts... It's quite impressive Since it always starts even with low starting revs engine is fine I would say. That leaves me with several options only: Battery: I don't think so since it doesn't become worse with all lights on (incuding added lamp-pod)... still I can start the car and the lights don't dim that much. Starter Cables I added extra ground cable from Gearbox to chassis but almost no change Ignition advance: I find on the web that too big advance can cause this issue due to too high compression before TDP. Anyone faced this issue also? Is there any other item I missed? I will check ignitiion this evening. I need to solve it quite urgent and have not much time to check a lot of things since I have a rally on Saturday. Thanks a lot. |
01-30-2014, 07:57 PM
I´d check the thick positive cable form battery, if the end/conections are fine, and whould try a different starter motor after that.
01-30-2014, 08:17 PM
heat soak into the starter motor.
01-30-2014, 10:23 PM
Lol what a coincidence, i have exactly the same problem.
ハチロク |
01-30-2014, 10:36 PM
Factory starter motor has a heat shield attached, plus there are
heat shields attached to the factory exhaust downpipes. If all of these are missing, heat soak is a known problem with the AE86 starter motor. You could try using zip ties to secure a layer of reflective heat shield material around the body of the starter (double sided silver stuff with reinforcing fabric between the layers. Whatever you can buy at your local speed shop... kind of like this... Cheers... jondee86 |
01-30-2014, 11:55 PM
"more input Stephanie"
Was that a statement or a question ? lol :wink: An analogue brain in a digital World |
01-31-2014, 02:50 AM
Good question...
Maybe Johnny 5 can help with some technical input... He knows about cars and stuff Cheers... jondee86 |
01-31-2014, 07:53 PM
I don,t get the "more input Stephanie" thing... But it's à cool saying from now
Anyway, made a ground cable directly from battery to the engine and iT Sems to work! I Will put THE heatwrap also. Ifproblem returns I Will get à New starter. Off. topic: how to swich off. THE dictionaire or change iT to english on ithe iPad ?? Als you can see it's using capitals and so whenever hè wants to |
01-31-2014, 10:17 PM
Sorry Dino... it's from an old movie... Short Circuit (1986).
http://www.youtube.com/watch?v=Pj-qBUWOYfE Stephanie is the girl and Number 5 is the robot with a self-learning function. When Number 5 was in need of further information he would use the expression "More input Stephanie...". It's at the end of the clip. Cheers... jondee86 |
02-03-2014, 08:04 PM
Problem seems fixed.
Put a ground cable (-) directl from battery to Engine instead of the additional from Engine to chassis. So problem seems to be the little f*cker going from battery ground to body. |
Engine starts/revs but no idle | GenkiMotors | 17 | 5,714 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 15,194 |
08-16-2018 01:36 AM Last Post: Bean |
Carb conversion but what is this and how ? | Allexz | 5 | 7,719 |
05-24-2016 08:48 AM Last Post: Allexz |
Bad vibrations /resonance starts at 5000 rpm | izanagi | 7 | 7,661 |
07-23-2015 05:02 PM Last Post: Bean |
got seat belts. but they rolled up | MC_JP | 8 | 9,192 |
05-06-2014 04:04 PM Last Post: banpei |
