(Catching up) OST-080 (and OST-074):Dan Dabbles in Dubs
06-13-2022, 05:33 PM
I have a friend with a few Porsche 924s.....
OST-074: 3 down........ I found in both Porsche heads the bowls to already be too large for making substantial improvements - short radius work and simple seat/bowl clean-up The big thing with both of these heads - guide wear OST-080: With this head the client went big valves... and the new seats broke the head A replacement was found - $$ Even with the bigger valves - there still wasn't a lot of material removed do to the oversize bowl/seat diameter. A finished chamber showing the big valves, and the multi-angle valve job. On the exhaust side there was some room in the port walls.... On this one the client converted from factory EFI, to something a bit less fuel efficient..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
Messages In This Thread |
(Catching up) OST-080 (and OST-074):Dan Dabbles in Dubs - oldeskewltoy - 06-13-2022 05:33 PM
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 1,795 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 2,191 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 1,461 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,188 |
(Catching up...) OST-081: STOP... do not touch if you don't know wtf you are doing | oldeskewltoy | 0 | 1,161 |
06-17-2022 09:07 PM Last Post: oldeskewltoy |
