Camshafts... what is your desire?
03-21-2013, 09:20 PM
As many of you know I've been working on clearing space @ a local race shop.
Well, they have BOXES of old camshafts... there are picking through the lot to see which ones are either repairable, OR grind-able to new dimensions......
And here is where you come in... What is wanted?
Would you prefer repaired 288+ duration 9.5+mm lift cams??
OR...
Would you prefer these cams be ground to 272 or less durations, with lifts under 9mm???
expected price on these should be under $500 for a pair
So what say you?????
Dan -
03-22-2013, 06:48 PM
If you can get me a pair of camshafts delivered to the UK for less than £400 @ 250-260 duration max lift 9.0mm i'd be happy - highly unlikely though!
03-22-2013, 07:08 PM
$500 = ~£330 and I doubt the shipping cost more than £70 / ~$105
So less than £400 sounds realistic to me Wink
03-22-2013, 07:20 PM
272 with 10,5mm lift perhaps Smile
What make is it, and how used are they?
Restoring my AE86, all the way... Going JDM style Big Grin
http://www.aeu86.org/viewtopic/ae86/p/150463#150463
03-22-2013, 07:38 PM
These are all Atlantic type cams so all are over 280 duration. Some are TRD.
Dan -
03-22-2013, 07:54 PM
Another thought....
what about selling them as "repairable" they may have a damaged journal, or lobe. In this situation they could sell for $100-$125 per cam
Dan -
03-23-2013, 03:14 AM
288 with 9.5mm lift Thumbs up!
03-23-2013, 08:08 AM
So a set of 280 with about 10.5mm lift would be possible?
Now my question is that to much duration when I plan to use a SC14 with 1mm oversize valves, ported head, larger injectors 2,5" exhaust? With a MAX of 8500 RPM...
03-23-2013, 02:41 PM
Not an expert but 8500rpm and 280 duration sounds just right.
Not sure if you need that much lift with supercharger and OS valves.
Photo How to add photos to your posts banpei 2 970 01-17-2022 10:31 PM
  what is your opinions on these head gaskets... CHOPKIN2 5 4,024 04-09-2018 05:29 PM
  KE70 - need your help! zemosh 2 4,304 03-19-2015 07:42 PM
Last Post: willy
  About to order Camshafts Alex170984 5 5,360 06-18-2013 12:54 PM
Last Post: Alex170984
  Need your help,looking for a rallcar thats looks like this ditn 17 17,058 04-11-2013 07:13 PM
Last Post: ditn
