Brake advice - master cylinder
08-18-2017, 10:28 AM
i have aps up front and kouki booster kit.
works fine i think. if interested i have modception one with 2 bolt patern brand new. |
08-21-2017, 12:43 PM
(08-18-2017 07:55 AM)Project D Wrote: Kouki BMC are 7/8" yes, and it should be fine with RX7 calipers. (08-18-2017 10:28 AM)ditn Wrote: i have aps up front and kouki booster kit. That's great guys! Thank you for your help it's really appreciated! I am running FD calipers in front as I managed to bag the pair (with a Mazda rebuild kit) for £100! I'm planning on replacing the BMC anyway as it has a leak so I may go for the SW20 Turbo one, just to make sure. I know I'll likely need a Brake Bias valve to try and balance it out anyway so might as well overhaul the full system. *I LOVE the wealth of knowledge in the AE86 community * |
08-21-2017, 03:21 PM
Just in case, FC and FD calipers are the same mechanically speaking (the differences are only aesthetics) and the specs are very close to the original AE86 or SW20 calipers.
We are talking less than 10mm² of total piston(s) surface. (2027mm² for the AE86 vs 2036mm² for the RX7 and SW20 calipers) One of my friend have FC calipers with the stock 13/16" BMC on is AE86 (zenki) and it work OK, but the pedal travel is a bit long. PS: apparently not ALL SW20 turbo came with 15/16" BMC, some used 7/8". If you want to go that way, here is a exemple of the 15/16 version: http://www.ebay.co.uk/itm/282608737104 |
4AGE cylinder head plug removal | Ivan141 | 5 | 1,189 |
Engine advice needed | spill86 | 14 | 14,512 |
09-15-2015 10:43 PM Last Post: spill86 |
Correct connection brake master cylinder? | bozu | 5 | 6,706 |
torque setting head cylinder bolts | izanagi | 1 | 4,494 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
Dimensions clutch master cylinder | bozu | 2 | 5,538 |
04-16-2015 07:11 AM Last Post: bozu |
