4age 20v and 16v engine mounts the same?
05-09-2007, 12:22 PM
upon installing the 4age in ae86 would you have to fabricate motor mounts or would you bea able to use the motor mounts that are allready there???
05-09-2007, 01:18 PM
Please make the topic titles relevant. "4age 20v" might sound relevant for you, but if we have 40 topics with all the same title like "4age 20v" no one can actually find a specific topic either in the search or in the forum overview. "4age 20v and 16v engine mounts the same?" would suit this topic title much better. So I took the liberty to change it now.
About your question: You asked about the same question earlier: http://www.aeu86.org/viewtopic/4age-20v-...sr5/t/4996 If you would have read the technical FAQ you would have known you can just re-use the engine mounts because the A-series have the same mounting points. Just have a look over there and most of your questions will be answered already. You can find the engine specific FAQ here: http://www.aeu86.org/index/engine/cat/9/...post=58121 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
05-09-2007, 01:32 PM
05-10-2007, 11:59 PM
Well I have expereince for I've already installed a 20V block into my AE86 and the regular mounts will bolt up... BUT the cast iron AE86 transmission support brace on the driver side will NOT fit the 20V block! The block is cast ever so differently that the brace will snap when installation is attempted. The passenger cast iron brace fits... so you must decide if you want a driverside brace of not... and if you do, you will have to fabricate the support brace
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,243 |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 18,886 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 17,991 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 5,898 |
AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 8,527 |
