4age 16v 1st and 2nd generation cams and not only difference
09-15-2013, 04:28 PM
hello mates
i own an ae92 hatch gti (eupopean specs) 2nd gen engine 3/1988 i believe that i have the 232 degrees cams that on of the basic difference from the 1st gen 4age. i know that i have the piston with 10.1 compression cause i have rebuilded the motor recently.... so my question is the 1st gen was more powerfull with the 240 cams? 4age 16v to FR 20VT |
09-15-2013, 10:18 PM
Apsogos Wrote:so my question is the 1st gen was more powerfull with the 240 cams? not really..... a lot of it it has to do with dynamic compression ratio... some call it "trapped compression" Note how toyota did not evenly change the cam timing, but they removed 7 of the 8 degrees from the point the intake valve closes. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-16-2013, 08:24 AM
so i try to figure out....in my engine that is properly rebuilded with compression about 10.6 , a new free flow exhaust system a better air intake filtering system,an 20v header ,european specs, if i install the 240 cam , will i gain more power?
P.S The blutop 1st gen was performing the same power with 2nd Gen tvis ae92 engines? 4age 16v to FR 20VT |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 19,007 |
Help me AEU86, you're my only hope | Nakilad | 38 | 12,893 |
04-10-2021 05:19 PM Last Post: Nakilad |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 18,293 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 6,015 |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 15,184 |
