4AGE block differences explained (incl. some eyecandy)
02-12-2013, 05:17 PM
Post: #31
[Walaki]D`Lair Wrote:Alex170984 Wrote:This has already mangled my melon Nah it'd ruin the driveability of the car - supercharge yes, turbocharge no. |
02-12-2013, 08:39 PM
Post: #32
Alex170984 Wrote:[Walaki]D`Lair Wrote:Alex170984 Wrote:This has already mangled my melon That is exactly my fear too...so I bought an SR20DET :mrgreen: :mrgreen: :mrgreen: :E AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
02-12-2013, 09:23 PM
Post: #33
Not so much candy.... but factory service manual info never the less
Rod clearances AE86 and AE92 Rod Clearances AE111 Mains... AE86 AE92 AE111 Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-12-2013, 11:17 PM
Post: #34
Coming along nicely, although I wasn't a big fan of club4ag still a lot of info has been lost since it crashed.
AE86 ex-daily |
02-12-2013, 11:25 PM
Post: #35
Yes i had alot of info bookmarked there,should have saved it to the pc
I will take out the engine/crank in the weekend and take pictures then, not possible right now. Should lift the mystery arround hybrid 4AGE from late 1986/1987 a bit |
02-18-2013, 12:00 PM
Post: #36
Due to realising that I have indeed got 9.4:1 low compression pistons – I am yet to double check if I even have a 7 rib block – as I just assumed it would be!
Did the engines which these pistons were used in, run TVIS? My TVIS did not work even though I swapped over two manifolds – it could just be a loom fault however. Could someone clear that up for me poss? |
02-18-2013, 12:10 PM
Post: #37
Alex170984 Wrote:Due to realising that I have indeed got 9.4:1 low compression pistons – I am yet to double check if I even have a 7 rib block – as I just assumed it would be! All bigports were running TVIS. Simply put the TVIS is based on 4 parts: the flaps with actuator, vacuum canister, vacuum hoses and trigger solenoid. Obviously if any of those are faulty or wired/connected wrong way it won't work. Also a non TVIS ecu is a possibility. AE86 ex-daily |
02-18-2013, 12:28 PM
Post: #38
Its not the ECU as that is still the original supplied with my MR2.
I did swap a working tvis manifold from my old mr2 engine onto this one and it didn't work, so it must be a loom fault. |
02-21-2013, 11:35 AM
Post: #39
Mercifully I do indeed have a 7-rib block!
So, if I have low comp pistons does that mean i have a low comp engine? |
02-21-2013, 11:41 AM
Post: #40
the block has technically nothing to do with compression - so yes low comp pistons equal low compression
AE86 ex-daily |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,274 |
Clutch differences LUK vs Exedy | r.ave | 2 | 4,354 |
05-27-2021 09:30 AM Last Post: r.ave |
BT head with ST block. | CHOPKIN2 | 6 | 6,452 |
02-06-2018 06:27 PM Last Post: mad.matt |
How important are dowell pins on a 4age block | spill86 | 5 | 6,802 |
01-13-2016 11:19 AM Last Post: spill86 |
7 rib block for a bluetop head? | dinkers542 | 7 | 8,705 |
11-04-2014 01:44 PM Last Post: zenki |
