4AGE block differences explained (incl. some eyecandy)
02-11-2013, 04:06 PM
Alex170984 Wrote:Are they 20mm on 10.3:1 smallport and 20V pistons high comp?
yes they are.
I UPDATED THE FIRST POST SO READ IT AGAIN FOLKS
02-11-2013, 04:13 PM
Uzelac Wrote:There must be difference in height since dome is a bit bigger at HC pistons.
why I said this Wink
Bean Bandit Wrote:the rest of the dimensions are the same disregarding the differences due to the dome design.
02-11-2013, 05:52 PM
i'll post up a picture of my new and old pistons later...
02-11-2013, 08:53 PM
Bean Bandit Wrote:I do know about it and if it had a 42mm crank then the pistons were 10.3:1 th only sub low comp (sub 10) piston with 20mm pin was the 4AGZE and they are 8.9:1
anyway I wasn't really listing all the different versions merely the oddball OEM block at the top compared to others.
You are not right, the AE92 bigport engines with AFM came with 20mm pin 9,4:1 pistons!
02-11-2013, 10:45 PM
Here is my old piston with a 20mm pin
Sorry about cleanliness
[Image: AEU86 AE86 - 4AGE block differences expl... eyecandy)]
Here is the new piston
What are they?
02-11-2013, 10:52 PM
probably AE92 bigport AFM 9,4:1 CR pistons!
02-11-2013, 10:58 PM
I haven't got an AFM
02-11-2013, 11:04 PM
ZDoman Wrote:probably AE92 bigport AFM 9,4:1 CR pistons!
I stand corrected, the dish is the same as other 9.4:1 CR pistons... first time I see one of those with a 20mm pin.
02-11-2013, 11:07 PM
Great so i've got shit pistons
02-11-2013, 11:12 PM
wouldn't call them shit just lower compression than a smallport one
  Question about 4AG 20v Engine Block CHACAMAN 1 763 06-10-2022 05:17 PM
  Clutch differences LUK vs Exedy r.ave 2 2,750 05-27-2021 09:30 AM
Last Post: r.ave
  BT head with ST block. CHOPKIN2 6 5,456 02-06-2018 06:27 PM
  How important are dowell pins on a 4age block spill86 5 5,944 01-13-2016 11:19 AM
Last Post: spill86
  7 rib block for a bluetop head? dinkers542 7 7,817 11-04-2014 01:44 PM
Last Post: zenki
