16v distributor hole plug
09-20-2016, 10:39 AM
Spend +2 hours scouting the webs for such a plate... Does nobody make those? I read that a engine block water freeze plug can be used but I'd rather do it properly with an o-ring or some sealant.
- Niels |
09-20-2016, 11:42 AM
(This post was last modified: 09-20-2016 11:44 AM by demee76.)
16v distributor hole plug | |||
09-20-2016, 11:51 AM
(09-20-2016 11:42 AM)demee76 Wrote: http://www.sq-engineering.com/upgrade-pa...e-16v.html I know that one, but I want to completely remove the distributor assembly. I am running a crank sensor now. |
09-20-2016, 12:28 PM
Do you have access to a CNC, given time I can draw up something in CAD.
AE86 ex-daily |
09-21-2016, 11:52 AM
09-21-2016, 02:29 PM
Considering the fact that changing the cam sensor already involves a bit of custom modifications, I guess the market isn't big enough
AE86 ex-daily |
10-10-2016, 10:52 PM
New product from JSP... not yet listed on his webpage
![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-11-2016, 09:59 PM
The cheap option would be a 36mm freeze plug or just a plate with some FIPG.
(I know someone who actually did it with an aluminium plate) |
10-12-2016, 11:13 AM
(This post was last modified: 10-12-2016 11:15 AM by harkes.)
Nice! Thanks Dan!
And as you say Project D - a plate and some FIPG would do the trick also ![]() |
Plug ID | kazi | 6 | 4,881 |
02-17-2019 10:07 PM Last Post: kazi |
Anyone know what this plug does? | Super86 | 3 | 4,906 |
08-01-2016 03:57 PM Last Post: Nakilad |
Changing distributor when carb 4age | izanagi | 14 | 12,430 |
07-04-2016 03:27 PM Last Post: Uzelac |
4AGE 16v RWD Bigport Diagnostics Plug? | Rascal21 | 2 | 6,576 |
11-15-2014 09:31 PM Last Post: Bean |
Distributor position and cranking | pack | 13 | 15,528 |
07-01-2013 11:08 PM Last Post: pack |
